What air compressor do you guys use?
Old 03-19-2015, 04:04 PM
mikes68charger
My Feedback: (34)
Default What air compressor do you guys use?
Ok I have only been in this hobby going for 4.5 years now with the last 3 or so with big war birds and several jets.
I started with some cheap pump I had.
Then I noticed the guys at the feild were using the $29 Habbor Freight pump
Well I think my 2nd one is on its way out. I have been using a 2200 4s lipo and I tend to fill my jets to 110 psi most with 2 tank systems
So you guys tell not to buy cheap so what are my options?
Old 03-19-2015, 04:19 PM
M3Baker
M3Baker's Avatar
Sears 19V inflator, $59. You will have to buy the battery separately. The battery is interchangeable with their blower, so get one of those too. Works great.
Old 03-19-2015, 04:26 PM
phjoker
phjoker's Avatar
Love this compressor
Old 03-19-2015, 04:27 PM
rhklenke
My Feedback: (24)
rhklenke's Avatar
I just bought one of these:
http://www.homedepot.com/p/Goodyear-...6000/204814139
It seems rugged. I'm going to power it with a 5000MAh 3-cell LiPo.
Bob
Old 03-19-2015, 04:34 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
I got excited for a minute, I thought you were asking about compressors to spray paint with :-(
Old 03-19-2015, 04:42 PM
afterburner
My Feedback: (18)
afterburner's Avatar
+2 on the Craftsman 19.2 compressor. It doesn't come with a battery or charger. It's actually cheaper to wait for a Sears sale and buy a one or two 19.2v drill kit which comes with one or two batteries and a charger than it is to buy the battery and charger alone. When they have a sale the compressor can be had for around $45.00 I keep a drill and charger in my trailer.
Old 03-19-2015, 05:18 PM
Vincent
My Feedback: (61)
Vincent's Avatar
Will the sears compressor pump up to 120-130lbs??
thx Vin...
Old 03-19-2015, 05:21 PM
afterburner
My Feedback: (18)
thx Vin...
Yes. I usually stop at 110 but it will go higher.
Old 03-19-2015, 05:22 PM
Vincent
My Feedback: (61)
Vincent's Avatar
Are you running the nicad or lithion pack??
Old 03-19-2015, 05:25 PM
George
My Feedback: (57)
Originally Posted by phjoker
+ 1
+3
George
My Feedback: (57)
thx Vin...
I go to 120 in the Shockwave, no problem!
Old 03-19-2015, 05:47 PM
Frank Ts Stuff
My Feedback: (130)
Frank Ts Stuff's Avatar
We have tried a bunch of different ones and always return to this one at our shop......Gel cell is only good for 1-2 seasons but easily replaceable with a new battery from Tower or elsewhere......and you can charge your cell phone while you are pumping! ;-p
http://www.homedepot.com/p/Campbell-...Bt4BoCGqnw_wcB
Old 03-19-2015, 06:13 PM
afterburner
My Feedback: (18)
I run both. The NiCads are ok and will probably work for the whole day when new but after a season they may not. There are two or maybe three different Lithium packs and even the cheapest ones are pretty good.
Old 03-19-2015, 07:40 PM
gregg f
My Feedback: (20)
gregg f's Avatar
Vin
I charge the lithium maybe once a month.
I fly 2-3 days a week.
Old 03-19-2015, 08:49 PM
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
Same thought, I have a makita mac5200, work great with my iwata lph80 and lph100 guns, 8 cfm @ 40 psi @ 120 volts.
Old 03-20-2015, 01:40 AM
gunradd
My Feedback: (9)
gunradd's Avatar
After going through a bunch of the cheap ass ones I bought the craftsman like the others have recommended and could not be any happier with it. Money well spent in my book.
Old 03-20-2015, 05:05 AM
Greg Wright
Greg Wright's Avatar
+++++1 on this one. I have recently taken out the the original battery and replaced it with 2 6000Mah 7.4V lipos run in series to make it a 14.8 volt system.
They last a couple of weekends of flying before needing recharged.
Old 03-20-2015, 05:35 AM
vinnyjet
My Feedback: (39)
vinnyjet's Avatar
Craftsman 19.2 compressor lithium
vinny
Old 03-20-2015, 06:21 AM
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
+1 on the Sears compressor, but replaced the original Nicad battery with a Hobby King Lipo.
Old 03-20-2015, 07:29 AM
RC Larry-RCU
I use the same model. Original battery lasted 5 years!!! Just replaced it last spring. Unit is compact, displays accurate pressure and hasn't shucked the needle like may compact air comp's do!
Old 03-20-2015, 08:05 AM
Zeeb
My Feedback: (41)
Zeeb's Avatar
I looked at a lot of compressors when I started filling air tanks on models. The Sears unit is the best of the bunch if you ask me and I would not bother with buying the NiMH batteries for the thing. Get the Li-Ion starter pack which includes the small Li-Ion battery and a charger that will do both battery types.
Yes the Sears unit will go, I think, to 150lbs. has a digital pressure readout on the back of the unit and you can set an air pressure and it will shut off if you want. I like that air pressure readout to check accuracy of the mounted gauges and I have a Corsair which has the little post thing to indicate air pressure which is pretty much hidden in the cockpit. The air pressure readout on the Sears unit allows me to see what's in the system.
Old 03-20-2015, 08:45 AM
FalconWings
My Feedback: (57)
FalconWings's Avatar
Buying this one today. Done with $40-60 cheap inflators. I have burned out an average of one per flying model. Planning on buying Sears warranty too. This will hopefully be my last one,
Also, Craftsman's will inflate your care tire, easily. Not so with the other crap sold by Lowes, HF.....
David
Old 03-20-2015, 08:59 AM
stevekott
stevekott's Avatar
+5 Great Compressor. After you buy the Battery System you might as well get the Drill, Vacuum, Worklight ......
Old 03-20-2015, 12:31 PM
BILLYDSRC
BILLYDSRC's Avatar
I picked up a Craftsman's 19v one in there closeout bin for 5 bucks!! I use a 4000mha 5s LIPO batt on mine! It works great!!
Old 03-20-2015, 07:36 PM
skippyc5
My Feedback: (244)
Same one that I have used for the last 6+ years. Same battery, works great!!
