Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Finish a Sheeted Q500 Wing
Old 08-27-2016, 07:19 AM
sahartman21
Default Finish a Sheeted Q500 Wing
In this thread it will show how add the tips, ailerons, and cover the wing with fiberglass cloth.
Below are the sheeted wings that are the start of this thread:
ID:	2178422   Click image for larger version
Old 08-27-2016, 09:22 AM
delateurj
Love your threads Scott. Looking forward to this one.
Joe.
Old 08-27-2016, 09:42 AM
sahartman21
Start by marking a center line on the leading edge.
Rough shape the leading edge with a razor plane and sanding block.
I followed with a sanding block and special L.E. tool.
ID:	2178429   Click image for larger version
ID:	2178430   Click image for larger version
ID:	2178431   Click image for larger version
ID:	2178432   Click image for larger version
ID:	2178433   Click image for larger version
ID:	2178434   Click image for larger version
Old 08-27-2016, 09:45 AM
sahartman21
The tips were trimmed with a razor saw and sanding block until the tips were square.
ID:	2178436   Click image for larger version
ID:	2178437   Click image for larger version
Old 08-27-2016, 09:50 AM
sahartman21
The wing must be trimmed at the trailing edge.
Measure and mark a line so that the wing will have a 9 7/8" cord.
A razor saw was used to trim the width. I followed with a sanding block with 60 grit sand paper.
ID:	2178439   Click image for larger version
ID:	2178440   Click image for larger version
ID:	2178441   Click image for larger version
ID:	2178442   Click image for larger version
Old 08-27-2016, 09:55 AM
sahartman21
A sanding block was used to sand the trailing edge until it was shape.
Note: The trailing edges on my wings have two or three pieces of 1.6 once fiberglass cloth between sheets of balsawood.
ID:	2178444   Click image for larger version
ID:	2178445   Click image for larger version
ID:	2178446   Click image for larger version
Old 08-27-2016, 01:00 PM
sahartman21
I traced a wing tip from a Sam-Rai on to a lightweight balsa block.
A jig saw was used to cut them out.
ID:	2178473   Click image for larger version
ID:	2178474   Click image for larger version
ID:	2178475   Click image for larger version
ID:	2178476   Click image for larger version
Old 08-27-2016, 01:03 PM
sahartman21
The outside outline of the wing was traced on the balsa blocks.
I continued cutting them out with the saw.
ID:	2178482   Click image for larger version
ID:	2178483   Click image for larger version
Old 08-27-2016, 01:11 PM
sahartman21
Gorilla glue was used to attach the wing tips.
Begin by wetting the surface with a damp towel.
Apply a small amount around the outside and tape parts in place.
Set the wing out of the way to dry.
ID:	2178487   Click image for larger version
ID:	2178488   Click image for larger version
ID:	2178489   Click image for larger version
Old 09-05-2016, 08:44 AM
sahartman21
Strips of 1/64" plywood are traced and then cut out using scissors or equal.
ID:	2179645   Click image for larger version
ID:	2179646   Click image for larger version
Old 09-05-2016, 08:48 AM
sahartman21
The slot location was identified with an ink pen and then cut with a razor saw.
The strips of wood are inserted into the slots and then glued in place with thin CA.
I sand off the excess glue at the joint with a sanding block.
ID:	2179649   Click image for larger version
ID:	2179650   Click image for larger version
ID:	2179651   Click image for larger version
ID:	2179652   Click image for larger version
Old 09-05-2016, 09:06 AM
sahartman21
The tips were trimmed and then sanded to match the airfoil of the wing.
A ruler was used to check if additional shaping was required.
ID:	2179658   Click image for larger version
ID:	2179659   Click image for larger version
ID:	2179660   Click image for larger version
ID:	2179661   Click image for larger version
ID:	2179662   Click image for larger version
Old 09-05-2016, 09:11 AM
sahartman21
A line was marked 5/8" from the glue joint.
Another line was marked about 5" from the trailing edge and goes to the corner (at the trailing edge).
I begin by shaping the front half with a pocket knife. Then shape the rear part.
After the tips are roughed a course sanding block is used to finish shaping.
ID:	2179664   Click image for larger version
ID:	2179665   Click image for larger version
ID:	2179666   Click image for larger version
ID:	2179667   Click image for larger version
ID:	2179668   Click image for larger version
ID:	2179669   Click image for larger version
ID:	2179670   Click image for larger version
Old 09-05-2016, 09:14 AM
sahartman21
Some spackle is applied at the joint to fill as required.
ID:	2179672   Click image for larger version
ID:	2179673   Click image for larger version
Old 09-05-2016, 03:31 PM
sahartman21
Pieces of dowel must be added to the cores to reinforce the area.
Approximate the location of the holes on the top of the core.
Small holes were drilled to verify the location on the plywood hold downs.
ID:	2179780   Click image for larger version
ID:	2179781   Click image for larger version
ID:	2179782   Click image for larger version
ID:	2179783   Click image for larger version
Old 09-05-2016, 03:38 PM
sahartman21
A hole saw (drill) was used to drill the holes in the wing.
Just turn the bit by hand until it is through the surface and core.
Close the hole on the bottom of the wing with a piece of electrical tape.
Cut pieces of dowel to fit and glue them in place with a mix of finishing epoxy and micro balloons.
ID:	2179785   Click image for larger version
ID:	2179786   Click image for larger version
ID:	2179787   Click image for larger version
ID:	2179788   Click image for larger version
ID:	2179789   Click image for larger version
ID:	2179790   Click image for larger version
ID:	2179791   Click image for larger version
Old 09-11-2016, 11:24 AM
sahartman21
The following pictures show how to apply the fiberglass cloth to the wing. They are from the Candy Kane thread.
A piece of Taffeta (dress liner) is used as the hinge surface on the ailerons.
I cut pieces about 1" wider and longer on each side than the ailerons.
Apply a thin layer of finishing epoxy over the surface and lay the Taffeta over that.
ID:	2180660   Click image for larger version
ID:	2180661   Click image for larger version
ID:	2180662   Click image for larger version
ID:	2180663   Click image for larger version
Old 09-11-2016, 11:33 AM
sahartman21
I follow with a piece of fiberglass cloth big enough to cover the entire wing. The weight can be from 0.5 ounce to 1.6 ounce glass cloth. I typically use 1.1 to 1.6 ounce fiberglass cloth on this surface.
The wing tips are subject to abuse and they can be made tougher by adding another layer of cloth. I used 1.6 ounce on the tips.
The center section is reinforced with 3 or 4 layers of additional fiberglass cloth (1.6 ounce).
3M77 is helpful in holding the cloth in place. I just apply a small amount to hold the glass in place.
ID:	2180665   Click image for larger version
ID:	2180666   Click image for larger version
ID:	2180667   Click image for larger version
Old 09-11-2016, 11:36 AM
sahartman21
I piece of peel ply (taffeta, or nylon polyester blend fabric) is cut big enough to cover the wing.
Old 09-11-2016, 11:41 AM
sahartman21
Mix about 1 1/2 ounce of finishing epoxy and add a cap of 91% alcohol for thinning.
Drizzle this over one side of the wing. Use a squeegee to spread out the epoxy.
Mix another batch of finishing epoxy and spread it the same.
ID:	2180670   Click image for larger version
ID:	2180671   Click image for larger version
Old 09-11-2016, 11:47 AM
sahartman21
Cover the wing with the peel ply and lay the wing on the wing bag.
The wing bag is made from a 4 mill thick piece of tarp. It is cut big enough to fully cover the wing and peel ply.
Place a long piece of paper towel over the top of the peel ply. Place a piece of rope at the wing leading edge.
Run a bead of latex caulking where the tarp joins.
ID:	2180673   Click image for larger version
ID:	2180674   Click image for larger version
Old 09-11-2016, 11:56 AM
sahartman21
The tarp was folded over to close the surface.
Most of the air was removed from the bag by running the vacuum pump. The bag was then placed between the wing shucks and some weight (qts. of paint) was applied to keep parts in place.
The pump was turned back on to remove the rest of the air. The vacuum pump is set to keep about 6 inches of Hg on the surface.
The wing is allowed to dry as required.
ID:	2180676   Click image for larger version
Old 09-25-2016, 10:08 AM
sahartman21
Default Finish a sheeted Q500 Wing
The wing was removed from the peel ply and a sanding block was used to trim the edges.
The surface of the wing was lightly sanded with 220 grit sandpaper on a sanding block.
ID:	2182779   Click image for larger version
Old 09-25-2016, 10:11 AM
sahartman21
The fiberglassed wing weighed in about 14.6 ounces.
ID:	2182781   Click image for larger version
Old 09-25-2016, 10:15 AM
sahartman21
This morning another wing was fiberglassed and placed in vacuum bag. The method was the same as the earlier one in this thread.
ID:	2182783   Click image for larger version
