Micro Shark from glasscraft
My Feedback: (66)
I finally got one of these little planes. It calls for a TD .010 should I go that route or will a .020 be faster? For the .010 I could run a 2x4 prop at about 26,000 or a .020 with a 2.5x5 prop around 20,000. Thoughts on what will make it move?
How did you source that?
You can look at my work with the NANO and NANO II for speeds up to 130+
NANO TD .010 / 40,641 RPM / 110.63 MPH / 2.5x3E Prop
https://www.youtube.com/watch?v=EFIJiDjF3D4 Published on Apr 3, 2016
Best Static 32,219 rpm / Best Pass / 40,641 RPM / 116 MPH (per prop calc.)
Doppler Wave Scope software best pass: 178.04 Km/h - 110.63 mph
35% Nitro / 76F winds 6 to 8 mph / 2.5x3E cut down from E-flite 3.75x3
Check out the machine work on this TD .010 ... drool drool
https://www.youtube.com/watch?v=NP5ptRXy87g
Seen this thread ..
https://www.rcgroups.com/forums/show...1519588&page=2
https://www.youtube.com/watch?v=zx3z55nthFI Published on Apr 3, 2016
Lil Speedy TD .020 / 3.75x3 / 31,257 rpm / 148.37 km h / 92.19 mph
Another good reading from a pass about 40ft up / 153 km h / 95mph
Winds 6 to 8 mph. 80 F / Per Doppler and audio app best passes
Seen this thread ..
In the description I have (2.5x3E cut down from E-flite 3.75x3)
The Nano is best viewed with a 32in monitor = )
If you have enhanced frame control you can get some good snap shot
views as it zips by. I use slow mo in my video software to pull out still
shots to post from time to time.
There are no APC props worth using for the TD .020 perhaps with
there line of drone props coming out they will explore smaller sizes
soon.
soon.
Here are some good pics to put things into perspective one with the stock .010 prop.
The last pic has the engine displacements in order from left to right .049 / .020 / .010 the slowest one does 118 mph.
Top end speed is only limited by prop selection once the plane is complete so you mod new ones till you found the top end.
The props that tend to be the keeper for my general flying are the one that gives good thrust and speed after I am happy with
finding the max possible speed which is the initial goal. These are the fastest Cox powered RC planes documented on You tube.
The .049 has a new prop yet to be tested based on previous results 118 mph it will bust 130 with ease.
The .020 will take the Nano 1 to 150+ it has hit 130.4 (4P) with the .010
The .010 will take the Nano 2 odds are good for 140+ mph, it has hit 123 with a 3P prop the 4P is next.
What are the specs on the Glasscraft and how did you find one?
To really haul arse with a TD.010 you need to be in the 2 - 3.5oz RTF range
The NANO 1 (3oz) has a 18in span the N2 has 16in span 2.2oz.
I imagine the TD .020 will be the better choice if you want top end speed.
The battery can be placed to get the TD .020 in check CG wise. If you can
squeeze in a throttle sleeve and 3rd servo as having control of the speed will
for sure make the maiden flight more viable for survival should the trims and
throws be a handful.
The TD .010 can keep the weight off the frame and make landings less harmful
over time if the Sq. In. is less than 40 the N2 is 36 and is just fine if landing into
any breeze but down wind the low weight has the elevator working hard to scrub
off speed. The N1 is a perfect no fuss plane with a TD .010 with the TD .020
It will be a bit more of a handful with so much power.
You can reference the size differences here to extrapolate your final engine
choice.
The N1 could have been improved for the TD .010 with what I know
now these proportions are perfect for a bit more speed with good stab stability.
You can compare further with the glasscraft design. Of course if we where talking
elect. all this would be easy peasy everything counts with IC for best performance.
Servo choice and rx control the room S1 lipo vs 4cell nicad the N1 helps with room
the glasscraft I imagine will hold 1.9g servos with ease.
choice.
The creator is still alive and kicking but getting one made is the big question.
I think he has retired in all regards.
I would be happy just to snag the glass fuselages and fab the rest. Thank
goodness for thin ply it's a easy way to make a lean, low weigh,t tough machine
with thin walls to keep as much room inside as possible.
I have bought two sizes of carbon sock to stretch over foam plugs then use gasoline to melt out
the foam. I have seen this done with hand toss gliders back in the 90's my friend from LA was
making them all the time with fiberglass.
What is the dry weight of the existing craft as it sits? Can you take a nice up close side view and
top view pic, post the length and max width at the wing saddle one could duplicate a reasonable
facsimile.
facsimile.
That is small alright looks like a TD .010 would be the easy choice for fit.
I wonder if anyone has tried the TD .020. A Pee Wee is a bit heavy due to
the back plate run time is sub 2 mins needle settings vary, with a stock prop
19.8 to 20.5k static has been reached. I have managed 25k ish with lower weight
smaller dia. 3P props good numbers for a reed valve engine. 3.7 x 3E
I saw a pic once of one of the tiny JM models with a VA .049. C/mon, maybe you can fit an .061 in there..
On the TD .020, Skipper's done way more than I have, but early in the game I cut a Driskill 5x2.75 1/2A combat prop down to 3.75" and messed with the tips. The performance gain over the stock prop was impressive.
https://www.youtube.com/watch?v=PwkxfJ8_gQE Published on Mar 5, 2016
TD .020 / 3.75 x 3E Prop / Best Level Pass- 29,554 RPM / 84 MPH / Throttle Sleeve
Static at launch 22,529 / 4.5oz thrust / 36w / per prop calc
Best dive down wind out of 3 video's / 31,419 rpm / 89.3 mph
RTF 5.3oz - Actually has unlimited vertical / 35% Nitro / Run time 8.06 mins
I can't say that the .020 will be faster because they are both pretty quick and get blisteringly quick when you start changing the props. Out of the box, the .020 would be faster but to be dead honest John and I were well over 70mph (stock motor and prop are good for 35 or so) just playing with the props with the MicroShark. The hot .010 setup was the .020 prop cut down to 2-9/32" with the tips swept back and re airfoiled. It spins in the 32k range with this prop, stock prop turns 27,400. Most .010's are delivered with a loose ball socket, you'll want to keep up on this if revving this high.
I strongly preferred flying mine with a sheeted foam RG-14 wing.
No idea if John is still making kits anymore, I stopped flying with him over a year ago. He's a retired Vietnam vet and has made kits since the 1980's-at first it was a full time job in addition to his day job, then it was a part time thing when he became allergic to the resin he uses. For most of the time I have known him, he wasn't ever "out" of the kit business but had definitely slowed down-he definitely earned it. That man and his wife literally made thousands of kits, and I can tell you from experience, it isn't easy, and it's a lot like Work if you care about what your are putting in a box.
You could try calling him, just keep in mind he's a retiree in his 70's so if he makes you a kit it won't be there in 3 days like you overnighted it from Hobby King. He's a real nice guy, might end up chatting for a while about airplanes anyway.
586-773-7069
That was my PeeWee Penetrator.... I wouldn't put a VA on a MicroShark/Yellowjacket, torque rolls would be a handful.
I get really good run time with a 10cc tank and stock prop
https://www.youtube.com/watch?v=Lyknz70Eds8
https://www.youtube.com/watch?v=Lyknz70Eds8 Published on Mar 23, 2016
Stock black prop 3x1.25
3rd test flight In the hand 25,516 rpm / Best pass 39,002 rpm. Last flight of
this day (5th flight) made a record pass of 41,985 / 61mph see other vid of that pass.
Lil NANO was looking for some Skat Cat some skiddy kitty maybe Mike will get his on
vid next yr.
vid next yr.
