AMT??? What's it worth
Old 03-13-2017, 06:54 AM
Wildvortex
Default AMT??? What's it worth
I have this turbine that was stuck in with a bunch of others. It is aproxamatly 3.75 - 4 in. There are no markings except a hand engraved number: 891018. Was told that it looks like an AMT but he was not sure.
ID:	2205171   Click image for larger version
ID:	2205172   Click image for larger version
ID:	2205173   Click image for larger version
Old 03-13-2017, 07:19 AM
patf
patf's Avatar
Looks like an AMT Mercury... depends on condition and accessories but anywhere from 500 to 1200 on the top end i would imagine.
Old 03-13-2017, 07:51 AM
patf
patf's Avatar
you have a task in front of you, if you post where you are located, you may be able to get some help. also if you post pics of the parts you have, some of the members here should be able to help tie them back to one of the turbines. you are really helping her out and that is to be commended.
Old 03-13-2017, 08:09 AM
Wildvortex
This is all I have here that is not definitely tied to a specific turbine
ID:	2205183   Click image for larger version
Old 03-13-2017, 12:06 PM
patf
patf's Avatar
Not sure what the board is, is there anything identifying on the back side?
the other is just misc 'festo' fittings, valves and a felt filter
Old 03-13-2017, 01:17 PM
mikes68charger
My Feedback: (34)
It looks a lot like my first AMT Mercury which I got on this site 5 years ago for $500. But you need a pic of the controller and pump.
Old 03-13-2017, 02:59 PM
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
Without at least the ecu it's virtually worthless. A new ecu from amt is very expensive. There are others that you could probably make work but as was just mentioned a complete mercury with ecu, pump, etc is worth generally 500 to 600 bucks. If a guy has to buy an ecu and pump just to make it work it's hardly worth it. I've seen guys selling amt ecu's from time to time but pretty rare.
Old 03-13-2017, 03:07 PM
Wildvortex
Well, there is another box over there marked jet so probably have the rest of it. He wouldn't have bought the turbine without all the other stuff to make it run.
Old 03-13-2017, 03:08 PM
Wildvortex
I will have to look tomorrow afternoon.
Old 03-13-2017, 07:35 PM
LGM Graphix
My Feedback: (22)
If you find ecu and fuel pump let me know.
Old 03-14-2017, 02:15 PM
Wildvortex
Haven't found anything yet. There is so much to go through. I just came across a Gryphon and a F-86 airframe.
Old 03-14-2017, 02:48 PM
rcjetsaok
My Feedback: (7)
rcjetsaok's Avatar
AMT USA Mercury in working condition is worth about $500.00 - $750.00.... Pegusus , $1,000.00 - $1,200.00... Netherlands is a whole different story... It's ashamed about the values, they are without a doubt the best most bullet-proof engine made... They have always been behind on electronics but the engine more than makes up for it... Been running a USA Mercury bought in 1999 second hand still running perfect, never in the shop once... Original bearings and all !!!
Dan
Old 03-14-2017, 03:54 PM
Wildvortex
What does the computer and pump look like on one of these?
Old 03-15-2017, 06:54 PM
c/f
Definitely a USA AMT Mercury AT180. .
I have 7 AMT's and have had no access to service since 2005 , nor have I needed any since 1999. Works without any ability to adjust any parameters. It just works.
Name:	AMT PEGGY.jpg
ID:	2205480   Click image for larger version
Old 03-16-2017, 04:16 AM
Wildvortex
Thank you for the pictures C/F. Now I have something to have his family to be on the lookout for.
Old 03-23-2017, 02:32 PM
Wildvortex
Look what I found today
Old 03-23-2017, 02:40 PM
Wildvortex
I picked up a HE-162 today. That turbine was purchased for this I Believe.
Old 03-23-2017, 08:42 PM
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Awesome! That's a version 1 ecu. There are a few of us dinosaurs still running them, if you have any questions just ask.
Old 03-24-2017, 04:14 AM
Wildvortex
Thanks, I will be looking to sell it though. Hopefully as a package with the HE.
Old 03-29-2017, 03:58 AM
Wildvortex
Guy interested in the turbine says that he noticed the EGT sensor is missing. Is this turbine equipped with a EGT sensor?
Old 03-29-2017, 04:01 AM
Wildvortex
Isn't this the little wire thing strapped to the outside of the can running a wire to the back of the turbine?
Old 03-29-2017, 04:32 AM
Dr Honda
Dr Honda's Avatar
Yep.... it's normally strapped to the outside of the can.
****EDIT***
I see it in the pictures in the first post.
Old 03-29-2017, 08:50 AM
Wildvortex
That is what I thought potential buyer said it is missing from the pictures. Will send this along to him. Thanks
Old 03-29-2017, 10:12 AM
c/f
Your original picture does not show the yellow plug which is male on the turbine which then plugs into the yellow plug which is female on the ECU that would clearly show that the thermocouple probe is included these are only a $10 industry standard thermocouple so don't let that fool you
Old 03-29-2017, 12:53 PM
Wildvortex
Ok another mystery item. Does this belong with the AMT?
