Belgian f16 flying demo-video
Old 03-28-2017, 08:16 AM
hmjets
Default Belgian f16 flying demo-video
BEAUTIFUL FLYING DISPLAY AND NICE AIRCRAFT SCHEME,AFTERBURNER PROBLEMS??
https://www.youtube.com/watch?v=8p57R1Isuz4
Old 03-28-2017, 11:23 PM
chrigui
yes A/B problem ... there is video showing A/B blow and following landing
Old 03-29-2017, 04:55 AM
FalconWings
My Feedback: (57)
FalconWings's Avatar
That's no A/B blow.....those are flares followed by landing. That's how they finish their demo routine.
Saw the whole video and did not see any afterburner issues at all.....performing flawlessly.
Old 03-29-2017, 06:04 AM
mauryr
https://www.youtube.com/watch?v=x51UYlumFS8
The afterburner flame front is messed up the whole flight... definitely not flawless..
Old 03-29-2017, 06:53 AM
FalconWings
My Feedback: (57)
That's a different video.
There is really no physical description as to how an afterburner flame should look like. It could certainly look different at different day light conditions. Engine was running fine, otherwise he would not be able to maneuver like that.
What you see there is a classical scenario of running into your own wake, causing inlet distortion and a short phased compressor stall. It is a lot more dramatic at full power, as he was. The ball of fire you see is simply raw fuel.The compressor stall activates the warning light, so the pilot probably aborted because of that.
Old 03-29-2017, 07:43 AM
mauryr
I am no afterburner expert, but it seems to me that this is a 'proper' afterburner flame (seen at night for maximum visibility):
Notice how the flame starts wide and full and tapers evenly
Now this is the afterburner from the first video in the OP (not the one I posted with the unburnt fuel explosion):
Notice how the flame is not full at the nozzle (maybe because of light? I don't know), but how it becomes wider as it's further away from the nozzle... It also looks much longer than the one in the first picture, considering night vs daylight conditions.
My guess is that this afterburner was already faulty in the first video and was not able to burn all the injected fuel. The extra fuel only burns at the very end of the flame.
The explosion seen in the second video looks to me like a puddle of fuel shot out by the exhaust and ignited outside the engine. Doesn't look like a compressor stall at all to me.
Anybody with real knowledge of this stuff care to enlighten us?
Name:	Screen Shot 2017-03-29 at 23.33.14.png
ID:	2207514   Click image for larger version
Name:	Screen Shot 2017-03-29 at 23.32.16.png
Old 03-29-2017, 08:02 AM
hmjets
http://www.f-16.net/forum/viewtopic....352199#p352199
Old 03-29-2017, 08:12 AM
mauryr
When a manifold becomes 'coked' it will affect it's ability to equally distribute the fuel around the circumference of the manifold. This will create high fuel-flow areas, and low fuel-flow areas within the augmentor. These fuel flow imbalances will then cause hot/cold streaks, or overly rich/lean areas of combustion.
Here's our answer!
Old 03-29-2017, 08:41 AM
FalconWings
My Feedback: (57)
"What I see in the photos of this post would lead me to believe the augmentor spray manifolds are 'coked' but without augmentor anomaly, (MFL/PFL or pilot reported) there is no reason to troubleshoot the streaking. Then again, they may have already been inspected and found to be acceptable according to installed engine (aka flight line) limits"
Again....there are no afterburner flame visual standards. If the engine runs fine, it runs fine. The ball of fire you saw was not afterburner related, you clearly see the short phased compressor puff. He landed because of that, not because the engine had any malfunction.
Old 03-29-2017, 09:20 AM
rgburrill
rgburrill's Avatar
Finally is video that really is spectacular instead of the ho-hum videos so many post here and others call the spectacular fights.
