Storing gas engines during off-season?
Even though Walbro have for several years now been using gaskets and diaphragms that are ethanol compatible in their carbs are repair kits, many of us here where all our pump gas is ethanol blended have adopted the practice of adding one of the available ethanol stabilizer like Star Tron to our fuel mix.
Been running gas only (no glow) for quite a while now. I can share with a fair degree of certainty that any decent 2 stroke oil has a gas stabilizer built into it. This makes running the carb dry a complete waste of time - unless the engine might be going into storage for SEVERAL years!
The reason WD 40 is working above is that it's wetting the carb valves which depend on moisture to seal - not that it's a bad idea if you are faced with a dry carb (as in a new one) or a carb that's been run dry. In fact, many experienced gas users will tell you NOT to run the carbs dry to avoid having to deal with a set of dry internal carb valves (they do not pump well, if at all, when dry!). The preservative that's built into decent oil will let you store an engine unused for 2-3 years with no trouble! I've had them go much longer. -Al
On advice I got several years ago from my friend and engine guru Ralph Cunningham ( Antique ) I stopped running my engines dry and draining my tank after flying as the unburnt fuel helps to keep the tank plumbing and carb diaphragms flexible. My two preferred oils of choice, Red Line and Stihl both have gasoline stabilizers inbuilt, so my adding an ethanol stabilizer to my fuel mix is really just for my peace of mind.
ahicks (06-06-2020)
