Question on F18F from X-Treme Jets
Hello Guys,
I have received my CMJets tank and it does not fit my F18, I have to remove some material on the fuse seperation if I want to fit it.
Before going this route, maybe I can try to repair the old tank.
The joint between the 2 shells is broken, I'm attaching a picture of it.
What kind of glue can I use ? Can I use standard epoxy ?
Thanks !
Thanks !
I already applied epoxy all other the crack and on all the joint.
I will apply some layer of glass tomorrow.
Thanks for your reply
#31
I'll try to reinforce the joint and I'll make a filling test - without forgetting the pressure cap (...) this time - and see if I have any leaks.
Now it is time to make a turbine choice. Plane without engine and dry is 11kg or 24.2 lbs, with the stock tanks I think it will be around 15kg (33 lbs), but still without engine. What kind of turbine would you recommend ? I want to try a Kingtech but do I stay at a lower ratio with a K160 or go bigger with a K180 ?
Thanks.
#33
Hey guys,
Time to move to setup the plane.
According to the manual found here : Skymaster ARF F
CG is at 140-160mm from the leading edge ?
Ailerons between 12-16 mm up/down
Elevator between 40-45 mm up/down
Flaps 20-25mm take off
Flaps 55-60mm for Landing
Does it looks correct or would you suggest any modifications ?
Thanks !
Thanks !
erh7771 (06-18-2020)
#34
Plane is ready to maiden.
I balanced the plane at 140mm which is the wing tube, so I just hang the plane by the wing tube and balanced it like this.
Any suggestions on this CG or it should be fine ?
AOA AUW is positive as explained earlier by most of the people
#36
