Rear Exiting Smoke tube question
I have used copper tubes (3/52” or so) for years now, so I know stainless isn’t needed. And my copper tubes are right behind my turbines.
If I were installing like you want, I would make a 100-120 bend on the end of the copper tube, insert a an exacto blade in the end and then crush the end of the tube with the blade still there to leave a small, flat aperture.
That’s what I would do!
EDIT: Oops, I meant brass too!
Carlos, are you saying that you see smoke fluid drip out of your smoke tube? With the turbine on or off?
A check valve wouldn't necessarily fix that since the fluid would still be moving in the same one way, ie out the tube.
The check valve is supposed to keep the smoke system "primed" so that you get smoke right away by not letting the smoke fluid flow backwards back into the smoke tank. But like I've seen, I haven't really seen a difference.
My Feedback: (7)
When driving home this afternoon it hit me, the Boomerang has the shut off valve in front of the turbine and lower than the turbine, the Turbinator's shut off valve is in front of the gas tank, the fluid line from the shut off valve to the engine is higher than the engine, so it has about 12" of fluid that can drip right after the shut off valve when it is open.
I will look how to move the fluid line to a lower position to stop the siphoning.
My Feedback: (21)
I have always made the exit at the rear of the jet. I used 3/16th copper tube. I would also run the tube between the double walls of the pipe. A slite bend to get the tip of the tube into the exhaust. A number 11 exact o blade then squeeze the end. A check valve where the brass and the fuel tubing meet to stop the smoke oil from draining back to the tank. I also would run a header tank, 2 to 4 oz's so you are drawing from a tank that is full. this helps with the negative g's so you don't get the on and off smoke through maneuvers.
Also the tube in the rear gives that scale look with a gap between the jet and the smoke.
My Feedback: (24)
https://baddogsmokes.com/turbine-smoke-tubes
The key is how good it atomizes the smoke oil. Made probably two dozen myself and bought many.
The best result I've had is these. Almost doubled my smoke time. Have a high volume one on my Boomerang
SPRINT with JetCat P80SE. Made of all stainless steel with I think .020" or .040" hole and 45 degree milled angle.
Talked with the guy couple years ago when he first stated making Jet tubes.
Definitely put a shut off valve just before the smoke tube. I open mine when filling tank, watch it reach the tube then shut it off and continue filling tank.
Then turn valve on just before take off. That way its all primed and it won't siphon the primer tank. I use a UAT for smoke also so I don't get any
breaks in smoke at any attitude. Have a TamJets pump on SPRINT and PowerBox on KingCat, both work great with UAT.
Good Luck
Good Luck
My Feedback: (53)
Good Luck
Good Luck
cptnassos (05-28-2020)
