Cortex Gyro Question/ Problem?
I am using a Cortex gyro in my 1/4 Vampire,with a Futaba 10J radio.I have it on
channel 9 using a 3 way switch.When I use it the up postion shows yellow, middle red and down green.I set the travel to 30 and 20 % on the travel limits.My question is It responds very slow to any movements, is this normal? This is my first gyro so I don't know what to expect.
Jerry B
Jerry B
Jerry B
Jerry B
My Feedback: (12)
If you use a 3 position switch one side of the channel will be heading hold and will kill the plane if switched at the wrong time. That being said you can plug a lap top into the gyro and make both banks be rate. If you do not do that on my futabas I use a program mix that allows it to only be on one side of the channel. I have found the 30% gear up and 50% gear down will work with all planes.I just slave it to the gear switch but also have a switch to turn it off. Dan
