Kit bashing the Top Flite Bonanza to a Barron!!
My Feedback: (12)
RE: Kit bashing the Top Flite Bonanza to a Barron!!
I have been looking into doing that. I used to own a B-55 Baron and a few Bonanzas. The B55 fuselage is the same from the firewall back. The wings need an extension on the tip. The horizontal and vertical tail surfaces would need enlargement. I would build a fiberglass nose and use the nose gear in basically the same position. The main gear could remain the same.
CA
Yeah, you go Teamscale! The size difference in the fin/rudder is just visible in those three views. If you need it, I can give you all the measurements or dimensions for the B-55. As said above from just about the firewall back the 33 is the same. I think the stab is close enough to work, too. The nacelles shouldn't be too hard to fabricate, either. This just looks sooo do able. Go for it, man!
My Feedback: (12)
Looking forward to this bash. I've been thinking about doing the T.F. Arrow as a Seneca 1.
Good luck with your project.
Chuck
Chuck
ORIGINAL: mustang105
Chuck
Chuck
The Seneca-series were derived from the old Cherokee Six/Lance/Saratoga singles. A Piper twin with the Archer/Arrow fuselage would be the Seminole. That wouldn't be too difficult a kitbash.
My Feedback: (22)
I was actually considering doing this with the Sig Bonanza kit. I'm building a regular BE33 now, but I have another kit just for the BE55 bash. So I am very interested in your project, although it is larger than the one I had in mind.
CA
Teamscale, that view shows the older style wind screen. A lot of Baron/Bonanzas have been updated to the so called "speed slope" wind screen. Mine has had this done. I forget what year it was changed at the factory. The 58 three view shows the newer profile. The TF Bonanza Wind screen will work perfectly. I just can not wait to see what you come up with. Are you thinking a 'glass nose or a built up nose?
While waiting for some glue to dry on the Arrow I rolled out the Barron drawing to see how the Fiberglass Spec. Canopy / cabin top fits.
Looks good. I have to resist the temptation to start cutting balsa. till the ARROW is finished!!!!
My Feedback: (90)
I saw the Piper post. Looks like you at the point where the airframe needs to "season" a bit. I think you should put it away for a while, and get this Baron going for the rest of us.
SEASON!!! Sure it will season on the static table at the Toledo show. It will season over the sunny skies at TOP GUN in Lakeland FL., at the NATS, Mint Julip, Scale Masters!!!! Build it and FLY it!! OK I got to get back to work , more fine sanding before covering!!!
My Feedback: (90)
Hey man how about a Twin Bonanza. It would be less major rework. I bet it would be the only one at any event you attend. Can you image an engine out on that! Here a link with some info:
http://www.airbum.com/articles/Artic...inBonanza.html
ORIGINAL: teamscalepilot
Monokote. yes I'll save the paint for the rest of you scale guys!! Started drawing the Barron 55, rudder's done. fuse started. Pictures soon!!!
Like the bash idea and nice drawings. Is that pencil on vellum? Wow. It's ye olde "CAD software???...We don't need no steenking CAD software" thing, huh? Good job!
Paul
My Feedback: (12)
ORIGINAL: Bax
Chuck
Chuck
Chuck
