Welcome to Club SAITO !
Old 02-28-2006, 09:53 PM
  #1851
bldrums
bldrums's Avatar
Default RE: Welcome to Club SAITO !
Dag Gone I got me a mess of stuff. Ok , I placed an order with Tower ( to use with a new Saito 1.25 engine ).
I probably should have called and talked to a sales advisor but .......naa
Ok, now heres the thing I dont understand all I know about:
I ordered those BRU LINE Filter Assembleys and some extra filter elements. Very nice but, how do you install the round rubber "o ring" of the filter over the square carb assembley intake?? The picture shows it fitting over the round part of the intake of an OS of some kind.
ie, what else do I need? I dont know but I think it may be an intake stack?? Or is an intake stack also a filter? DANG ! What do I get now.
Matter of fact, I ordered FOUR of the filters to do all my
Saitos........ It all used to be much simpler.....
I know this is a little stupid......but if you have a picture it will help this old boy like a 1000 words!
Old 02-28-2006, 10:14 PM
  #1852
William Robison
Bid:
Some engines, like the K&B 61s in the first picture, have a nice cone to slip the rubber part over, and you're done as shown in the second picture.
Sad to say the Saito carbs, being designed originally to have a sliding choke valve, do not have this nice cone. You have to add the stack, as seen in the third shot. Then you just slip the rubber over the end of the stack, and put the element back in it. Fourth picture.
Bill.
>>EDIT - Got one picture wrong. wr.
ID:	417712   Click image for larger version
ID:	417713   Click image for larger version
ID:	417714   Click image for larger version
Old 02-28-2006, 10:20 PM
  #1853
bldrums
bldrums's Avatar
Ok now Im clear. Thanks Bill. Do you know if one stacks fits all on the Saitos .56 thru 1.25 and would this be a Saito part only? ( Horizon )
Old 02-28-2006, 10:27 PM
  #1854
William Robison
Bid:
I just happen to have one in my hot little hands. It's part number SAI50GK93, and sad to say, it's only from Horizon. But happy to say, it's not expensive.
The one I have here now is going on an FA-82.
Bill.
Old 02-28-2006, 10:38 PM
  #1855
bldrums
bldrums's Avatar
Great!!
Thanks Bill, I preciate ya!
Old 02-28-2006, 10:48 PM
  #1856
bldrums
bldrums's Avatar
No , Im cool with Horizon. They are good folks. Granted, It would be nice to see Saito get a little less expensive but, just one more engine and Ill quit. Really.......just one more....one more plane and one more engine...........thats all............I can stop any time I want to!
Old 02-28-2006, 10:51 PM
  #1857
William Robison
:smurdiB
edirA4uoYkooTsneilA
!****wkcaBgnithyrevEeeSuoYwoNdnA
!waH
.lliB
PS: Maybe why you didn't realize you needed the stacks. Haw again. wr.
Old 02-28-2006, 10:58 PM
  #1858
w8ye
My Feedback: (16)
w8ye's Avatar
You spelled EVERYHTING wrong
Old 02-28-2006, 11:09 PM
  #1859
William Robison
Jim:
I did indeed. Spell check doesn't work on Alien talk. Sorry.
Haw.
Bill.
Old 02-28-2006, 11:12 PM
  #1860
bldrums
bldrums's Avatar
Ever since that ride........................I ....did you hear that?.......
Ill quit wastin Saito Club space now. Dont egg me on. We'el both git kicked out. [8D]
( how come u dont use these smiley things?)
Old 02-28-2006, 11:38 PM
  #1861
William Robison
beausol:
Apologies. Just realized that not only had no one answered your question about the FA-180 and airframe weight, I had not assigned you a number here.
So you are now number 208.
The FA-180 is more than capable of hovering a 12-13 pound plane. Accelerating up from a hover wont be like a Saturn V rocket, bit it will be adequate.
Bidrums:
The picture is for you.
Bill.
Old 03-01-2006, 12:04 AM
  #1862
Kmot
My Feedback: (24)
Kmot's Avatar
!sdnah ruoy no emit hcum oot yaw evah ouY
Old 03-01-2006, 02:08 AM
  #1863
sence-soared
HEY, CLUB SAITO, New guy on the block here,Ive got a few of these babies,first off the line is a goldberg ultimate 10-300 sporting a,need i say FA 100, swinging a 14x10 J ZINGER WOOD PROP, next in line is a HANGAR TWIST with a FA 65,SWINGING a J ZINGER 13X5 PROP, also got an OMP EDGE 540 PROFILE WITH A NEW "TODAY" FA 56, planning on somwhere in the range of a 12x4 or12x6 prop,see how it goes. Also saving my pennies for new power for my V2 KATANA 46, I believe there is a GK 82 IN MY FUTURE,That way i can get that other 4 stroke off my KAT. By the way,how would one go about getting EFLITE or HANGARNINE to make a mini TWIST designed exclusively for SAITO 30 ENGINES. HALF-A-TWIST....... WORKS FOR ME.
  #1864
Barfly
Barfly's Avatar
Thanks Jim,
The one I have is the only one I've ever seen. I bent the spray bay slightly, straightened it and now having trouble tuning it. Dunno if the spray bar is the cause, or something else. Without knowing what is different in the 'F' I'm not keen to order parts from the normal version.
My local hobby shops are only resellers, not much help on technical issues. Does Saito in Japan have a service center or e-mail contact? Thanks.
Cheers from the Barfly.
Old 03-01-2006, 02:23 AM
  #1865
William Robison
Okay Barfly, since you're an owner you are number 209. HANGERKING, you're number 210.
Barfly:
Further, I don't know about Malaysia, but we have a "Carb upgrade kit" available here, it includes all the fuel handling parts in the carb except the low speed adjuster.
Upgrade Carb, Rebuild Kit: 50-5
SAI50144 By SAITO ENGINES
You might check and see if your local shop can order it. Of course the part number there might be entirely different, too.
Bill.
Old 03-01-2006, 03:50 AM
  #1866
Barfly
Barfly's Avatar
Thanks Bill,
I'll check out that kit. I may have found my problem though, loose carb fuel inlet nipple and a tiny piece of crap inside the spray bar. I'll give it a new plug too, and see how it runs next weekend.
"Owner". Yes, I also have a 1.00. I'll talk to you about that one in another post. Thanks for #209.
Old 03-01-2006, 07:41 AM
  #1867
Jerry C
ORIGINAL: Jerry C
I have run into a problem with my new Saito 125. Ive run about a gal of fuel thru it, and it has developed a terrible squeal. I ran about 1/2 gal thru it on the test stand, it ran great right from the start. I than put it in the plane and had about 6 flights for another 1/2 gal. Running it rich all the time, the fuel was wildcat 15% extra preium with 18% oil 20% of that being castor. I had brought it back to the flight line and was in the prosess of running it out of fuel to put it away, and it started to squeal. I shut it down right away, looked it over very good, turned it over by hand and could not see, hear, or feel anything so I started it back up, still has a very bad squeal. If I was to guess I would think a bearing has gone bad. Any ideas?
Jerry
Hi Bill
I thought maybe you would jump in here and give me your opinion to.
Jerry
Old 03-01-2006, 02:03 PM
  #1868
rclement
rclement's Avatar
Hey Bill, Just wondering about the older Saito 72's. I've heard that they can have a problem with the backplate. (?) What's that all about? Rob
Old 03-01-2006, 07:30 PM
  #1869
w8ye
My Feedback: (16)
w8ye's Avatar
On the 72
There's been washers added under the backplate screws at one time.
The latest backplate has a fillet (Brace) added under the carb mount.
Old 03-01-2006, 08:18 PM
  #1870
William Robison
Jerry:
The "Squealers" I've run into have been the cam bearings. If it's in warranty send it to Horizon. If not, pop the back plate and set the engine nose down. Fill the crank case with your favorite after run oil and let it soak for a day or two, then try it again.
Before you fill it with oil look at the rear bearing, turn the crank and be sure it's turning correctly.
Rob:
The early FA-72 back plate wasn't stiff enough, the carb would vibrate, and the intake pipe would eat its seal at the cylinder end. As Jim said, the new ones are changed in design, and are also made of a stiller plastic. The FA-82 uses the same part.
Bill.
Old 03-01-2006, 10:39 PM
  #1871
lrr
lrr's Avatar
ORIGINAL: William Robison
Jim:
Haw.
Bill.
You need a copy of kcehC llepS ...
Lee
Old 03-01-2006, 11:04 PM
  #1872
rclement
rclement's Avatar
Thanks for the info on the 72 backplate.......
Old 03-01-2006, 11:06 PM
  #1873
loughbd
Banned
I love my Saito 60 schneurle ported two cycle ignition engine
Old 03-01-2006, 11:18 PM
  #1874
William Robison
Lee:
kcehC llepS? That's a good one. Wish I'd thought of it.
All:
For those of you who may be harboring some small (or large) amount of doubt, Saito did truly make a fairly large spark ignition two stroke engine. And it was supplied complete.
Bill.
ID:	418435   Click image for larger version
ID:	418436   Click image for larger version
Old 03-01-2006, 11:45 PM
  #1875
Thunderchild
Thunderchild's Avatar
Lee:
All:
Bill.
What was the date of manufacture on that Bill?
Thunderchild
