** Digitech Central Telemetric Unit for Jeti **
#276
#283
Danny
AeroPanda
#285
My Feedback: (20)
Digitech, Danny,
Here is a log photo of my 1/5 F-16 CTU data from a flight last weekend at FIF in NC.
Set up is CTU, B300F, Projet Hornet III ECU
Green = % fuel remaining
Blue = Turbine RPM
Red = CTU G
On this flight my fuel % remaining worked well till 53% and then stopped counting down. All other CTU data continues to transmit and log. In this photo I show turbine RPM, and G. I checked several other CTU parameters on this flight and they all show similar pattern. All other CTU data is recording and working but fuel remaining stops and says level at 53%. I have had this problem on several flights where the fuel remaining % stops at 48%, 44%, 42% etc and then level for the remainder of the flight. After a power off reset and new flight the fuel % will work fine for a few times and then freeze again and stay constant till landing.
I have had this happen with two separate CTUs installed in in two different jets. The other is an Avanti XXL with K-210G, and Kingtech G1 ECU. Same pattern just fuel % stops working at a number usually between 50-40%. It does not happen every flight but seems to be random. Sometimes with an overflow tank and fuel reset to 100% and sometimes without, just normal startup and fly.
Do you have any idea why and what to do to make it reliable. The fuel remaining % is the primary reason I am using the CTU and when it works its great. Still using timer as a back up.
Gary
Blue = Turbine RPM
Red = CTU G
Gary
#286
My Feedback: (10)
Digitech, Danny,
Blue = Turbine RPM
Red = CTU G
Gary
Blue = Turbine RPM
Red = CTU G
Gary
can you share:
your tx and version?
rx and versions?
you installed the lua script? Or using the telemetric only
#287
My Feedback: (10)
Another one:
can you also confirm the logifles that consumption then freezes also?.
fuel used
fuel consumed
and percentage all freeze?
i have never heard of this or ever seen it.
also you mention 2 brands of turbines.
that means 2 different ways.
the bf does its own consumption.
so we needmto find out where the culprit is.
only thing i never use is the fuel reset.
do you use it everytime?
fuel used
fuel consumed
#288
My Feedback: (20)
DS-24: FW v4.28 5/11/18
CB-400: FW v1.09
R3: FW v3.25
R900: FW v1.12u
CTU: FW v0.92 CFG 1
Lua: Twin Dashboard v1.1
I think Danny emailed you the log file for the above flight.
Thanks, Gary
#289
Gary,
I just got the log!
Can you check what the tanksize is set to in the engine ECU ? Also let me know what you have it set to in the CTU (I assume 6.8 liters)
Check if the ECU is set to 3.8 liters, and if so, you need to turn it up to the max it can be set to, and then re-test
I just got the log!
#290
My Feedback: (20)
Carsten,
We left on the family vacation yesterday and will return home on 6/9/19. I will check the tank size then. I did not know there was a place to set it in the ProJet ECU and have never checked it so there so there is no telling what it is set to. Also Danny told me the Qs were pretty bad on that flight. I will go back and check the rest of them also. Some other guys experienced low Q at FIF but the times I checked mine they were all very high.
Also the flight log you have where the fuel stopped counting down had a long delay waiting to take off, running on the taxi tank for several minutes. After being cleared for takeoff, we removed the taxi tank and I reset the fuel remaining to 100% before taking off. Not sure if the delay may have effected the fuel countdown or not.
Thanks, Gary
Thanks, Gary
#291
My Feedback: (10)
Carsten,
Thanks, Gary
Thanks, Gary
yes it does affect it!
since the counter is only reset in the CTU and NOT in the projet.
if its the same as the Jetcat it will count negative after reaching 0 ,so i think there is your error.
i also looked at your file , and there are some more issues , danny or carsten can tell you more about it.
we have sold a lot of ctu and never got a customer saying that the counter stopped.
#293
Hi Sandor,
Could you please advise if we still require a different firmware.sfw for the Jeti REX Assist Receivers?
If so, are you able to advise when you plan on combining both receiver types into the same file?
Regards,
George
Regards,
George
#295
Carsten,
Many thanks for your assistance, I've installed firmware.sfw V0.95 and the telemetry works perfectly with my JetCat 180RX.
However, the handheld GSU locks out i.e. I'm unable to scroll thru the menus. Any thoughts on what could be causing this?
George
George
#296
Regarding the GSU, it is (unfortunately) a well known problem A quick fix (if you are up to it), is to cut the 2 center wires in the gray flatcable that goes from the ECU/IO Board to the CTU. This will fix the problem (the long technical explanation is that the ECU/GSU have low resistance to load on the I2C bus from the ECU to the GSU (which is also coupled to the CTU, but not actively used).
So, basically cut the center two wires.
On the picture below you can hopefully see what I mean, cut the two wires with the green lines on them
You need to be careful splitting the cable, but with a knife or a wirecutter it is pretty easy
#297
My Feedback: (20)
[QUOTE=Carsten Groen;12527844]Gary,
/QUOTE]
Carsten,
I checked the ProJet ECU today and found the fuel tank size was set to 3000 ml. I reset it to 6800 ml to match the tank size in the CTU of 6.8 liters. I ran the setting up past 12,000 ml to see how high it would go and stopped. I'm not sure how high it goes. My taxi tank in about 1000 ml so my total fuel could never be above 7800 ml at start. What setting should I set the in the ProJet ECU tank size?
I noticed as I ran the ECU tank size setting up to 6800 ml that the % and fuel remaining in the CTU changed to negative numbers. Can you explain how the ECU setting affects the settings in the CTU.
Gary
/QUOTE]
Carsten,
Gary
#298
[QUOTE=Viper1GJ;12530711]
Gary,
you need to set the tanksize in the ECU as high as it can get. For ProJet and JetCat I get the fuel consumed by subtracting the the two numbers from the ECU, "fuel consumed" and "fuelsize" (and multiplying the "fuel factor" in the CTU to this number).
(all other engines I calculate the fuel consumption in the CTU instead, only JetCat and Projet I use the numbers from the ECU).
So, set the tanksize in the ECU to a very very large number, and the correct one in the CTU. Then retry. The numbers going negative when changing the numbers in the ECU is totally fine, the CTU uses the first reported "remaining fuel" from the ECU as a base. So need to restart CTU after changing the tanksize in the ECU so it gets the correct numbers.
Gary,
/QUOTE]
Carsten,
Gary
/QUOTE]
Carsten,
Gary
#299
My Feedback: (20)
[QUOTE=Carsten Groen;12530772]
Gary,
Carsten,
Today I set the tank size in the ProJet ECU to 20,000ml, the max size available. The CTU has been reset an tank size set to 6.8 L. It will probably be a few weeks before I can test fly again. Looking forward to seeing how it works now. Thanks for all your help and fast replies.
Gary
Gary,
Gary
