Reload this Page >
** Digitech Central Telemetric Unit for Jeti **
Old 12-30-2019, 04:38 PM
  #351
wgdenge
Hey Folks.
Installing a CTU in my new jet. Using Jeti DS24 and CB200, ect..
I am able to see the CTI from device explorer and I have updated using SD card.
Where do I get the cool dashboard? Is there instructions for install, ect..
Sorry if this has been explained before, but this is a LONG thread.
Wayne
Old 12-30-2019, 05:14 PM
  #352
Dansy
My Feedback: (53)
Dansy's Avatar
Originally Posted by wgdenge
Hey Folks.
Wayne
I think if you have version 5.02 on the TX you already have everything you need....
Go into the applications menu and choose ctu-twin...
Then you you see that apps select it make select as desired...colour ect. Then go into sensor /display.....it’s now in the Lua....select that it’s full screen page..
Old 12-30-2019, 06:33 PM
  #353
wgdenge
5.02 of Jeti or 5.02 of CTU??
I put latest CTU on, and there is nothing in the APPS folder for CTU.. :
Old 12-30-2019, 07:06 PM
  #354
Dansy
My Feedback: (53)
Dansy's Avatar
5.02 TX so Jeti......
Old 01-02-2020, 08:18 AM
  #355
digitech
My Feedback: (10)
digitech's Avatar
Hey Folks.
Wayne
you can find all manuals , software , firmware and lua scripts here :
https://www.digitech-aerosports.nl/product/783681/ctu
Old 01-03-2020, 05:11 PM
  #356
wgdenge
Hey folks, another stupid question. Where would one route the pressure-sensor line to outside of a jet like the Futura?
Cheers,
Wayne
Old 01-03-2020, 05:19 PM
  #357
Dansy
My Feedback: (53)
Dansy's Avatar
Cheers,
Wayne
I don’t do that I just leave it as is with the nipple....
Old 01-04-2020, 12:29 AM
  #358
digitech
My Feedback: (10)
digitech's Avatar
Cheers,
Wayne
its a static port not a pressure port.
if you use a turbine with no ducting you need to route it to a outside connection.
i drilled a small 3mm hole next to my front gear door, you can also 3D print a small static port .
Old 04-17-2020, 03:20 PM
  #359
Springbok Flyer
Springbok Flyer's Avatar
Sandor,
Please can you confirm that the CTU will work with AMT engines and on PowerBox Core. I want to order a CTU, but I need to make sure that it will work for me.
Thank you for your advice.
JanR
Old 04-18-2020, 02:19 AM
  #360
digitech
My Feedback: (10)
digitech's Avatar
Originally Posted by Springbok Flyer
Sandor,
JanR
yes it does work , also with amt
but we stopped doing support for the Core.
Old 04-18-2020, 03:53 AM
  #361
Springbok Flyer
Question
So will it not work on the CORE?
JanR
Old 04-18-2020, 03:55 AM
  #362
digitech
My Feedback: (10)
digitech's Avatar
JanR
yes it does work with the core.
even twin engine support , but there will be no more future updates.
if Powerbox decides to make a dynamic menu we wil reconsider support again.
until then it is what it is.
Old 04-18-2020, 03:59 AM
  #363
Springbok Flyer
Thank you Sandor, apologies for sidetracking your Jeti discussion. I will continue my questions with you on the messages.
JanR
Old 04-18-2020, 04:00 AM
  #364
digitech
My Feedback: (10)
digitech's Avatar
JanR
its no problem , its just im alone at the moment.
Trying to keep up with it all.
Old 04-18-2020, 02:34 PM
  #365
Springbok Flyer
Yes we are in difficult times - I have sent you a PM.
JanR
Old 04-18-2020, 04:18 PM
  #366
wfield0455
My Feedback: (7)
wfield0455's Avatar
Will the CTU Lua scripts run on a Jeti DS12 ?
Old 04-30-2020, 12:33 AM
  #367
winter1
winter1's Avatar
YAU!
Yet another update.
we just updated the LUA script
1. changed translation so that each language has its own file (e.g. nl.jsn). Trans.jsn now is just a list of languages. It only reads and loads the one it needs.
2. Replaced kph with kmh everywhere
3. added knots to speed units selection on the menu.
Please be adviced :
Best is first:
1. uninstall CTUautoT from your applications.
2. delete the digitech folder and the CTUautoT.jsn from your TX folder : apps.
3. copy again the latest files back to this folder (apps).
4. reinstall the LUA in applications.
Hi "digitech", it would be nice if you could prepare voice announcements and data on the display in CZ language for users in the Czech Republic. I noticed that voice announcements in CZ language so far they only work for autothrotle mode. Can we hope? ***winter***
Old 04-30-2020, 02:59 AM
  #368
Dansy
My Feedback: (53)
Dansy's Avatar
Pretty sure they would need someone that speak Czech......oh wait you do
Old 04-30-2020, 03:02 AM
  #369
digitech
My Feedback: (10)
digitech's Avatar
its very easy
open the lua folder in there you find all engine files in json and the audio files
here is a pice of code :
"brand": "Kingtech G2",
"message": {
"255": {
"text": "ECU Offline",
"speech": "ecu_is_off_line.wav",
"de": "ecu_is_off_line-DE.wav",
"active": true
so lets add CZ
"message": {
"255": {
"cz":"testcz.wav",
"active": true
Old 04-30-2020, 01:08 PM
  #370
winter1
winter1's Avatar
Hi Dan, as we all know, Jeti Duplex are Czech transmitters and accessories for controlling RC models. The Czech language is in the basic equipment of transmitters with other "worldwide languages" English, German, ...... There would be no problem in cooperation with the Czech manufacturer, if there is no one in the CTU team who knows Czech / which I do not even assume /. CTU was developed mainly for the Jeti system. And Jeti is a Czech company. Therefore, I took the liberty of asking /digitech-CTU/ to operate in the Czech language as well. ***winter***
Old 04-30-2020, 01:16 PM
  #371
winter1
winter1's Avatar
its very easy
"message": {
"255": {
"active": true
so lets add CZ
"message": {
"255": {
"cz":"testcz.wav",
"active": true
That would be ok. I believe that the setup will go smoothly. ***winter***
Old 04-30-2020, 01:17 PM
  #372
Dansy
My Feedback: (53)
Dansy's Avatar
Hi Dan, as we all know, Jeti Duplex are Czech transmitters and accessories for controlling RC models. The Czech language is in the basic equipment of transmitters with other "worldwide languages" English, German, ...... There would be no problem in cooperation with the Czech manufacturer, if there is no one in the CTU team who knows Czech / which I do not even assume /. CTU was developed mainly for the Jeti system. And Jeti is a Czech company. Therefore, I took the liberty of asking CTU to operate in the Czech language as well. ***winter***
‘Quite aware of all that LOL
Old 04-30-2020, 01:26 PM
  #373
winter1
winter1's Avatar
I know,
that you know it
that you have an overview. ***winter***
Old 05-26-2020, 12:58 PM
  #374
gbarnes
I'm having issues getting the LUA script to load on the TX. I have updated the transmitter (DS-24). Updated the CTU and can recognize it in device explorer. But, I cannot get the LUA to load. There are two files on the website. I am assuming I need only the LUAOnly and not the full version. How about a step by step of how to upload this file?
Gary
Old 05-26-2020, 01:06 PM
  #375
ww2birds
My Feedback: (14)
ww2birds's Avatar
Gary,
There is one file (the lua code itself) and one directory (which contains sound clips and other associated data). Both need to be copied for an initial install. After that, if the associated data does not change you can just get a new lua. In my opion, safer to always copy both .. they get copied to the /Apps directory on your transmitter.
If this does not solve the problem, PM me and I am more than happy to get on the phone with you this evening and provide any assistance.
Dave
