Carf rebel pro
#101
There is a CG stand available from Pacific R/C Jets that supports the larger jets. It works pretty good and isn't super expensive. Of course, there's always the Xicoy CG machine but it does take some setting up but is highly accurate.
skymaster68 (09-17-2021)
Skunkwrks (09-18-2021)
#108
So did that yellow paper rub through clear into the gray.
Have you tried some polish compound to see if it buffs out?
Nice scheme and colors
#109
My Feedback: (9)
it looks like paint or clear coat softened and bled into the yellow paper but I don’t think Carf puts and clear or any paint on the outside to my knowledge, unless it’s the special UV protectant coating that Mike said they needed to use to keep the flat neon magenta from fading , then that’s what transferred.
Either way it doesn’t buff out , it’s permanent .
always my luck, I never get a perfect looking plane, always something damaged or cracked or chipped
#110
My Feedback: (18)
My rebel had some of that, I used a clay bar and it cleared right up. I wanted to avoid using a harsh compound.
https://www.meguiarsdirect.com/megui...-clay-kit.html
#111
My Rebel Max showed up last night. I'm going to set it up the exact same as the Pro. I don't know if y'all want me to put the build process in this thread so I probably won't but, the only difference in cost when this is finished was the plane itself. All other components will be exactly the same as if I were putting it in a Pro. By the way, holy cow is this plane HUGE. It's quantity two of my wife!
Components:
Kingtech K235G4
PowerBox Mercury SRS w/ GPS
2 x Futaba 7108 RX's
Futaba 9177 Servos running @ 7.4 V
Electron ER50 retracts w/ GS-200 controller
5L fuel tank (may change to CMJets)
Futaba 32MZ
I can't even put the wings on in the house!
Components:
Kingtech K235G4
Futaba 32MZ
The following 2 users liked this post by smcharg:
chevronflyer (09-23-2021),
patf (02-03-2022)
#112
Yeah whatever was on that paper or the paper itself rubbed or if there is a clear on the outside of the plane it transferred to the paper . The exact patterns of gray crap on the paper matches the same pattern on the fuse bottom .
Then use a fine polishing/ finishing compound and a orbit buffer and it will be like new
Seems like the paint wasn't hardened completely, guess they were in a rush packing it up for the seacontainer shipment.!!!!!
#113
The CMjet tank are six liters, plus a smoke tank that fit in front of the engine , heres the link
I'm going to order these tanks for my Rebel Pro and gain an extra liter of fuel from the factory size
https://cmjets.com/pirotti-models/60-rebel-pro-6l.html
#114
My Feedback: (9)
ok I’ll give that a try thanks for the tip
#117
My Feedback: (21)
For anyone who has recently ordered and gotten their Electron Retracts through CARF, did you receive the newest versions of the ER-50's.
They would be the ER-50 eVo versions.
I would like to make sure that I am getting the newest version of these retracts. It's the first time I am getting a set of Electron gear.
smcharg (09-28-2021)
#119
I just got mine Thursday. The boxes say ER50evo retracts but the actual retracts don't say EVO. I thought they did but I guess not. There's not a choice for the older version on the boxes so I believe they are the Evo's.
#125
Hello Joe, I ordered mine from Electron directly to save a few dollars .
For my future Rebel Pro order through Mike McConville hopefully, it's being built now if everything is go correctly.
I would fasten some plywood 1/8 with hysol for some more structural strength.
