Carf rebel pro
#177
Good 2 know. I've never been a fan off fiberglass tanks. Thanks for the info I'm glad it's not ghetto atleast.
Carf has upgraded theirs from a rubber pung stop to the screw in the Carlos uses but it's a five-litre, with cmjets you can get a five or the six-litre which they also use in the Rebel Max.
I'm going with a 240 Swiwin motor with my high altitude I treated myself to the six-litre tank, and it's huh in length.
I received mine the other day and Carlos did an excellent job will adding a few decals under the epoxy finish just to make it very professional looking.
The decals of Rebel Pro and his logo plus I asked for a JetA logo and Jeti logo with the wind sock and it looks great.
Russell
Russell
#179
When I order my Rebel Pro I was unaware that Carf upgrade their tank fittings, I just need a large tank than the factories five-litre.
Janvdh (12-13-2023)
#183
That is a nice scheme, i ordered my in Cayman scheme in Yellow, should be here Feb-Mar .
The Intairo company went broke and remaining stock looks to be in Europe . I would rather use a Map tank, does exactly something and is a good hundred plus dollars cheaper.
Not as glamours but I plan on keeping my Map close to the engine and pump out of site, no need on spending 200-300 for a trap. Just my point of view.
#184
I have a mini map no issues. I guess I like eye candy. I want to get the cmjets tank too for eye candy reasons. It's only 50 bucks more than that ugly glass tank that carf sells.
But I do feel the itrap is a good product. I'm seeing some other brands that look similar. I'll look around I haven't bought anything new since 2018 and the landscape has changed. Is DreamWorks still the place to get stuff?
#185
I think Intairco are good trap , just don't like have two gaskets at the need of a glass cylinder making a seal . Maps website https://www.modelaviationproducts.co...-accessories/6
Dreamworks is a very good place for the majority of Jet stuff you will need and they also are keeping stock fresh as the supply chain permitts.
Friend of mine purchase all his jet products from them, excluding radio and servo gear.
Also check out the other Turbine and landing gear manufactures website as it's usually quickier instead of going through a dealer like Dreamworks.
essyou35 (01-21-2022)
#187
My friend is also a JR dealer as I just got eight Jr 8911 2K servos for my Rebel Pro , love the hardware and servos.
#188
My Feedback: (53)
Intairco is still one of the best UAT’s
#189
They are being sold by Modellbau https://www.final-modellbau.de/en/intairco.html.
Dreamworks doesn't carry any Map tanks by Intarico , so finding them here in North America is a harder search.
Ooops my bad.
#190
This is the biggest jet I've ever had. I did have a skymaster mig though, while not as big, the tail was HUGE. I tend to use hitech servos. 7954SH is my go to but I may be dated and not even sure those are available. They are HV programmable servos Ive come to trust.
Are they good for a jet this size? The control surfaces are fairly small compared to the flying tails Ive used them on.
Don't know your radio but I have come back to Jr servo's as they are very smooth, quiet and accurate. MKS I've used with very good success but are programable.
#191
I depends if you running 6.6 Life or 7.4 Lipo batteries and looks to be out dated and are replaced with something else.
I would concern them with them not meeting the required 25kg and I've had and seen a lot buzzing because they can't center, but that's my experince.
As long as you can get parts should be good maybe ,look at the new brushless servos for the elevator and rudder from Hitec they have a lot load placed on them.
#192
I was researching, sounds like savox and MKS servos are the way to go these days? Very strange as they seem to made for Rc cars. I do like the futaba servos for SBUS as I currently run the 14sg radio. I know its cheap but I have thousands of flights across several jets without even a single hiccup. But I do like that new core radio. I may look at upgrading.
Whats your thoughts on using a powerbox? I like the idea of using 2 rxs with 10K flying around out there.
What are you using in yours?
Seen someone is using these, is this the way to go?
https://aeropanda.com/collections/fu...roducts/hbl599
#193
You should look at the 8911S 2K JR servos, they are discontinuing the coreless but have a brushless version at but price point than the MKS's. Futaba servos are futaba, not really at the point of the spear and are more money than JR's...
Alot of guys like the core but it seems to be more limited in the multy later programming that the Jeti can do. Just from what I have heard and read about it and never owned one.
They are good radio it's just what you prefer , all the new radios use two receivers when you get into these size of planes. JR, Futaba,Jeti and even Spectrum use two satellites receives.
The Core and Jeti you can run a backup 900mhz receiver and one 2.4Ghz plus Jeti you can use a third receiver to turn on and off the plane.
You have should look up Harry Curzon on Youtube as he is the head teacher of the Jeti products to everybody.
I'm using a Jeti DS16 first genertaion tx with a CB210 power distribution box going to JR8911s 2K coreless servos on my jets. My Imac is Jeti with 200cb and MKS 599 servos and I haven't had issue with either setups.
JR's https://www.deeforce.net/product-page/s8911-bl-2k
It's more 14-16K when you have all the gear wing bags, leaf blower and all the stuff. Also a good source of JetA or Kerosene fuel.
#194
My Feedback: (53)
I don’t think I could go back to a regular TX been flying Jeti DC-16 and 24 since the beginning…..of Jeti North America….a Rebel Pro at least here in Canada is more like mid 15k….2x RX’s I feel is pretty much a must now days.
essyou35 (01-24-2022)
#198
It’s all on PB’s web site. SRS serial receiver system. Once the model is booted up it will run on one Rx. The power system is probably the only true redundant one where there is duplication on circuits that power the Rx and Servos. The great thing about it sharing the power is the batteries don’t work so hard.
if you are not tech minded go with the Mercury, it’s very plug and play and 15 servo outputs is enough for most jets, especially now with Electron gear where the controller deals with doors etc.
No one can tell me why 900mHz on the Jeti is anything other than a sales tool. If the 2.4ghz bit is taken down by something like a microwave the 900mHz is toast before anyway.
The most important thing again reading your posts is go with something people near you know so they can help. Every system available now is better than things were 5-10 years ago and we did not have many falling from the sky then…other than the same operator issues that will take down the most secure sophisticated tech available!
#199
I'm a little late to this party but if you like eye candy (me too), look at the Digitech line of UATs. They are very similar to Intairco. Dreamworks sells them and Chief Aircraft does as well. Note - I had to order a 6mm fitting and they were completely out of stock everywhere except BoomaRC in Austrailia. I ordered it dreading the shipping to the US and to my lovely surprise, had it in less than 1 week. Great service.
#200
Like Dave suggested get what others around you are using so you can get help.
I still love my Jeti radio after talking with the owner of Powerbox at the Tuscon shoot out he was very open to how his system was designed he said if he couldn't operate the system he sent it back to the engineers to correct it.
Very similar to Jeti but with his own ideas of how a radio should work, he said the 900mhz backup was because of European radio issues with signals and is used as a backup.
Your going to get FANBOYS who says their radios are the best but go with what you want, no bad choice here.
