Reload this Page >
CARF-Models Mig 17 build thread
Old 06-21-2022, 04:30 PM
  #126
kimhey
Originally Posted by Dave Wilshere
How much stuff are you putting on the front tray? It quickly comes out nose heavy.
Yes it does indeed. I have a CB400, the Electron GS200pro (running Er-50NG retracts), CortexPro and a bit more all installed under the front hatch. With my 3D printed cockpit/pilot/ weighing more than the one Carf offers, a have now added 900+ grams in the tail.
No 25kg limit in my country (150kg is the limit for model airplanes).
Old 06-21-2022, 05:43 PM
  #127
jackdiazccs
Batteries will be at the back of the bottom tray, together with the UAT / pump / ECU.
Jack
kimhey (06-21-2022)
Old 06-26-2022, 10:02 AM
  #128
Dave Wilshere
I’ve spent the weekend working on the AB ring. I really don’t get Unilight with ‘kits for s specific models yet there is not enough cable supplied to do the job. Anyway having wasted too much time sourcing wire I extended the AB cables to allow me to place the controller in the rear fuselage. It saves more connections coming through the joint, I may even find a place for the battery back there. The turbine tailcone is behind this area so heat should not be an issue.
I routed the cables so I can keep the tail control wires away from the AB cables.
Connection to the AB rings is an 8 pin MPX type
Old 06-26-2022, 11:47 AM
  #129
Newton5019
Are you planning on splitting the fus each time Dave ?
Old 06-26-2022, 12:27 PM
  #130
Dave Wilshere
No! But there maybe time it’s needed and the minimum number of connections without having a single point of failure is my normal way.
Old 06-26-2022, 12:40 PM
  #131
Newton5019
I’m sure your writing all this down for Paul 👍👍👍
Old 06-30-2022, 12:34 PM
  #132
Dave Wilshere
Back end is now wired. 3x Powerbox One4Two MPX leads. One each side for Elevator/Airbrake and one for Rudder/tail light.
Individual connections in the fin so no single point of failure. The elevator cables on opposite sides reduces the chance of anything taking out both!
Old 07-01-2022, 12:59 PM
  #133
Dave Wilshere
Mounting a JetCat P-220Rxi requires 6mm packers and the mounting plate notches filling in. I used 6mm carbon laminated ply for both.
Old 07-04-2022, 11:07 PM
  #134
Dave Wilshere
Working on wing wiring loom and starting to think about the canopy.
Using Powerbox leads throughout. 1131 One4Three to do the Aileron, Flap and Gear door servos. Then a combination to do gear and lights.
I’m not normally a snake skin sleeve person but where the lead goes down the leading edge it goes through carbon faced rib cutouts, so this was done to protect the wires.
Canopy frame prepared (Dremel all high spots) and painted grey ready for glass.
kimhey (07-05-2022)
Old 07-06-2022, 12:56 PM
  #135
Dave Wilshere
My wing connection system is hard mounted fuselage connectors and ‘floating’ wing. To ensure the connector clears the root rib structure I cover the root with masking tape, cut out the openings and using the spar as a reference transfer to the fuselage
Old 07-11-2022, 10:39 AM
  #136
Dave Wilshere
Finally finished the modified landing light, it was probably not worth the huge effort!
Old 07-11-2022, 01:13 PM
  #137
Pondus
Maybe, but it looks really cool.
Old 07-11-2022, 01:41 PM
  #138
Dave Wilshere
Yes, I’m happy enough with the result. There is a little more detail to add to the lens edge.
Started fitting the glass so I can get on with the cockpit. Front section glass cut into 3 so I could get a perfect fit.
I use magnetics and this little trick if you have ever handled these super strong magnets. Placing in pairs either side of a piece of wood they are easy to remove for placement.
jcterrettaz (07-11-2022)
Old 07-11-2022, 08:59 PM
  #139
TSHARK203
My Feedback: (206)
TSHARK203's Avatar
I guess i need to get mine done. Its been sitting in the same place almost from the time it arrived. I have done a bit of work to the cockpit. I took some parks for the extra Flytechniques Mig15 and added them to this cockpit. I find this one to be a bit sparse for the cost.
Also has anyone looked at adding smoke to the plane. I still trying to figure out where to put it.
Had to adjust to fit the MiG-17 canopy
Scale harness for the MIG
Latches in place. They still need to be weathered a bit.
Still need to finish out the top of the canopy around the mirror.
jcterrettaz (07-12-2022)
Old 07-12-2022, 01:16 AM
  #140
Dave Wilshere
Nice detail
Old 07-14-2022, 10:25 AM
  #141
Airforce7
My Feedback: (31)
Airforce7's Avatar
Hi Dave,
What AB ring settings did you go with? After some testing, I've elected to keep Mode 1, Option 1 with the rings connected in parallel (Diagram Connection 3). I connected the uniLight module to an AUX channel and set the travel range so that the light comes on at the upper portion of the throttle curve (from ~3/4 to full). Let me know, thanks!
Old 07-14-2022, 12:41 PM
  #142
Dave Wilshere
I can’t remember, I played around with the two options. Will look in am which I went with! If you can find Motors & Rotors on Instagram there is a video of it in operation!
Old 07-17-2022, 09:59 AM
  #143
Dave Wilshere
Andreas warned me the cockpit would take a while to install, he was not wrong! There is a lot of test and trim.
I realised too late that leaving the front side glass out until the canopy slides were mounted would have made life easier☺️
You can see how the track pulls the front down as the canopy finally closes. Getting the cockpit tub to seat under the top deck so the canopy shut line is consistent needs a little cleaning up of the rear tub shape.
Old 07-20-2022, 08:52 PM
  #144
Dave Wilshere
Canopy opening complete, it’s very satisfying when you operate it the first time. The large headed screw hooks the back of the canopy when it’s closed, this screw also limits the opening as it catches the canopy front drive mounting plate.
Old 07-21-2022, 12:23 AM
  #145
Dave Wilshere
canopy function
The following 2 users liked this post by Dave Wilshere:
jcterrettaz (08-10-2022), Skunkwrks (10-17-2022)
Old 07-25-2022, 05:27 AM
  #146
kimhey
not much, but a little something for you guys.
Old 07-25-2022, 09:58 AM
  #147
Turtlejets
Turtlejets's Avatar
What a monster!
Old 07-25-2022, 04:06 PM
  #148
Ron S
Ron S's Avatar
I haven't checked this thread in a while... I like the cockpit detail - wow - pretty cool!
I've seen 3 of these flying this year so far- Mississippi Jets, and Top Gun. They all flew great!!
Old 08-09-2022, 10:27 AM
  #149
Dave Wilshere
Difficult to photo, but this is how my wing gear door servo arm ends up when closed. SECRAFT 19mm Arm
Old 08-09-2022, 11:22 AM
  #150
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Maybe use a flashlight at a distance to illuminate the area then augment with phone flash.
